Why is the expansion hose a hard pipe?
Old Sep 6, 2020 | 06:26 PM
Stamford's Avatar
Default Why is the expansion hose a hard pipe?
I managed to break this expansion hose, so I'm temporarily replacing it with a length of rubber coolant hose.
My question is why is this hose actually a hard plastic pipe? Will using the rubber hose cause any issues like collapsing or anything else?
Thanks!
Old Sep 6, 2020 | 06:53 PM
RJ237's Avatar
I replaced mine with fuel line a couple of years ago, no problems.
Old Sep 6, 2020 | 08:13 PM
giandanielxk8's Avatar
I did the same and never looked back.
Old Sep 6, 2020 | 10:32 PM
Johnken's Avatar
Same here.
Old Sep 7, 2020 | 06:07 AM
Jon89's Avatar
Me too. Way back in November 2014 when I had to replace the coolant outlet pipe assembly....
Old Sep 7, 2020 | 08:09 AM
CorStevens's Avatar
it was made out of hard plastic because it looked nicer that way. It was rigid and followed a neat path with minimal support. Technically a metal pipe coated with a glossy surface would have the same result, but costs more. Plastic is cheap too.
Old Sep 7, 2020 | 10:28 AM
Stamford's Avatar
Makes sense. I was so proud I didn't break any of the breather hoses when removing the intake manifold, But when I replaced the manifold I didn't realize the expansion hose was trapped under the edge and snapped it in two. Stupid!
Old Sep 8, 2020 | 07:57 AM
fmertz's Avatar
FWIW, I replaced this plastic pipe a while back with a section of flexible hose "from the garage" as everyone else did. A while later, that hose had turned stiff, brittle and leaky. Must have been the wrong kind. I ended up replacing it with the Jaguar part, figuring it was cheaper than a tow...
Old Sep 8, 2020 | 08:53 AM
Jon89's Avatar
Yep, some rubber hoses are more durable than others. Transmission hose may be the best option for this particular application. I believe that is what I purchased for this replacement back in late 2014 and it has held up relatively well. That hose location certainly bakes there at the top of the engine bay....
Old Sep 9, 2020 | 08:17 PM
stu46h's Avatar
Same here.
MussieRon
16
Apr 7, 2020 08:49 PM
Z07Brandon
Feb 29, 2020 08:10 AM
vdpnyc
Dec 4, 2016 09:48 AM
34by151
Mar 13, 2015 10:27 PM
