Wifes 2000 XK8 will not crank. Please Help
WAIT. My son and daughter had the EXACT same issue, I just remembered. If my daughter would slam the trunk it would work again. We sanded the contacts and replaced the negative cable and she hasn't had a problem since. I have had some issues with the braided negative cables, so I switched to sheathed.
That 5a fuse without looking at the diagram is the one to the mirror lights and will prevent the car from starting. Often when removing the header people do not realize that the contacts for the mirror lights are inside the clips for the visors and end up shorting them out. First never over fuse it will bite you in you’re a_s. As for the concern that it was shorted and now it is not would concern me as I drive not knowing it will happen again but that is your call.
