Window problem
Old Jul 18, 2017 | 08:21 AM
dennisw's Avatar
Default Window problem
My 2002 xkr has got its window problem again.
I replaced the switches on the door lock mechanism about 5 years ago.
Checked all switches all ok
Any help please
Old Jul 18, 2017 | 08:41 AM
It would be good to know what the problem is. :-)
Old Jul 18, 2017 | 10:14 AM
dennisw's Avatar
When you open the door the windows goes down an inch. Pull handle again goes done 2 inches. Does not go back when shutdoor. Tried to reset memory many time,took mech out on bench all switcher are working ok.only way to lock car is to put window up climb into passenger seat to get the lock car.been in on it all day
Many thanks
Dennis
Old Jul 18, 2017 | 12:07 PM
Jandreu's Avatar
Just to be sure, you are in the car with the door closed when you reset the window memory, correct?
Old Jul 18, 2017 | 01:17 PM
dennisw's Avatar
Yes had the car for 7 years so I have set the windows many time when bat been removed ect
Old Jul 18, 2017 | 03:17 PM
motorcarman's Avatar
Door Module(s) or low voltage.
bob
Old Jul 26, 2017 | 05:15 AM
dennisw's Avatar
Sorted it out, it was the the door module all working now thanks for the replies��
