window switch button
Old Jul 4, 2017 | 01:07 PM
Rick Padilla's Avatar
Default window switch button
After a detailing, the cover (up & down arrows) on a window switch popped off. On one side the little ear that had the hole for the pivot was broken off. I bought another switch ***'y on eBay cheap, for the passenger side (lots of those available) thinking I'd pry off the cover, but I don't want to break it too. Any suggestions before I attempt this delicate transplant? Maybe a heat gun?
Thanx, Rick
Attached Thumbnails window switch button-red-cat-wearing-wires1.jpg   window switch button-img_2569.jpg   window switch button-img_2570.jpg
Old Jul 4, 2017 | 01:47 PM
BlkCat's Avatar
Rick,
I had the same thing happen a couple of years ago. I bought a replacement switch from the dealer. A bit pricy. I think it was around $100.
Installing it was pretty easy. You have to remove the wood surround. As I recall there is a screw which attaches that assembly which is exposed when you remove the rubber stuff in the door "card". I think there is just one electrical connection which is easy.
Not sure what a heat gun would do. The broken piece is replaced when you install the switch.
I remember the parts guy at the dealer remarked that he was surprised the switch last as long as it did.
Jack
Old Jul 4, 2017 | 10:23 PM
revauto's Avatar
Save your money and go to a junk yard (salvage yard) and get a window switch from early 2000's Ford Cougar, switch is exactly the same as the jaguars', hopes this helps you out and saves you money usually only cost me $5.
Old Sep 6, 2025 | 09:55 AM
ranoutoffuel's Avatar
Hi Rick
the same thing just happened to me.
Would you know is there is a separate spring beneath the plastic cover?
thanks
Stephan
1995 XJR
NYCJAG2006
Jul 19, 2023 07:50 AM
Sgmmiller
Sep 27, 2021 07:28 PM
gelair
Nov 7, 2014 08:11 PM
MattJ
Sep 23, 2014 05:07 PM
jomia092306
Feb 28, 2014 12:31 PM
