Window Switch Weirdness
Old Feb 16, 2015 | 10:14 AM
OldSpanner's Avatar
Angry Window Switch Weirdness
My drivers window switch stopped working. A brand new Jag unit arrived this morning quick install and guess what my drivers window switch opens the passenger window. Mirrors don't work at all. Any help, anyone?
Old Feb 16, 2015 | 06:21 PM
RCSign's Avatar
I wonder how long it's been setting on the shelf. I had my switch a few years ago start acting up. I took it apart(very carefully) the corrosion was all over the contacts I cleaned all of the contacts with 2000 grit sand paper, cleaned it, greased it with dielectric grease re assembled it. It took three times re-sanding it to work properly. If your new switch has been setting for a few years it could have could have corrosion built up on the contacts.
Good Luck
Old Feb 17, 2015 | 05:57 AM
jamdmyers's Avatar
Sounds like you may have plugged the connector incorrectly, but if not you might try a hard reset (remove neg battery cable, Touch it to POS terminal for 15 secs, reconnect to neg post) you will then have to reset you windows (hold down till beep/then up till beep on both sides)..
Old Feb 18, 2015 | 03:37 PM
OldSpanner's Avatar
Default more switch madness
Got the window switch sorted thanks for replies but now I have another problem. The bank of switches that controls heated seats , traction control etc. The lights work at night but the illuminator LEDs that turn on when the switch is on won't. Took it appart all looks in order. Anyone had a repair?
rentzoo
Nov 10, 2015 04:56 PM
LnrB
Sep 18, 2015 09:48 AM
RaceDiagnostics
Sep 13, 2015 02:22 AM
jagent
Sep 12, 2015 09:10 AM
1964Daimler
Sep 9, 2015 11:28 AM
