windscreen finisher is loose
Old Jun 29, 2016 | 03:23 AM
280zx-turbo's Avatar
Default windscreen finisher is loose
On my 2001MY the windscreen finisher on the upper right corner is loose. How is this finisher fixed? with clips or glue? Thanks - Daniel
Old Jun 29, 2016 | 04:47 AM
The trim is secured with clips around the perimeter of the windscreen.
The clips are embedded in the adhesive during the fitting process.
The top clip may have broken but could just need the trim pressing back onto it.
The usual procedure for fitting the trim is the fit the top corner first and work down to the bottom of the windscreen.
Old Jun 29, 2016 | 07:10 AM
RaceDiagnostics's Avatar
Here is a close up of what the clips look like.
Old Jun 29, 2016 | 09:28 AM
scardini1's Avatar
Daniel: Please post whatever it is you find / do. My upper right corner is also popped out a bit, but I just haven't taken the time to address it.
Thanks! - Jim
Old Jul 6, 2016 | 03:15 AM
According to the instructions from a member in a german forum I took off the trim. Unfortunately all clips broke or were broken before. (someone worked already on this issue)
Now I can not take out the broken parts of the Clips under Windscreen and therefore not put on new ones. I have to bring the car to a windscreen-replacement shop to do the work.They probably need to take off and on the windscreen.
RoadcraftNottingham
May 15, 2023 01:20 PM
Marque
Oct 13, 2016 08:24 PM
BlckCat
Sep 23, 2016 03:28 PM
280zx-turbo
Jun 30, 2016 04:20 AM
kulddy
Jun 24, 2016 12:10 PM
