wIPER mODULE ISSUE
Old Apr 1, 2011 | 12:52 PM
JAGme's Avatar
Default wIPER mODULE ISSUE
Does anyone know where the wiper module is located-
I have removed the glove box and see a blue module.
Is this the wiper module?
Old Apr 1, 2011 | 04:13 PM
WhiteXKR's Avatar
The XK8 does not have a wiper module per-se, but rather has a Body Processor Module (BPM) that controls dozens of functions, including the wipers.
There are, however two wiper relays (Run/Stop and Fast/Slow) which are controlled by the BPM in the brake booster enclosure. They are the two relays closest to the firewall.
Old Apr 1, 2011 | 05:10 PM
JAGme's Avatar
Smile Many Thanks White !!
I just finished changing out the whole wiper and motor assembly very easy actually !!
I will check the park microswitch and repair the orig then resell it later-probably never-----LOL-
Ill check the relays after I troubleshoot the used install-
Any info on setting the wiper arms properly after replacement???
I am assuming they were left in park position.
Thanks again for all the help
Old Apr 1, 2011 | 06:29 PM
H20boy's Avatar
no real magic in setting the wiper position, just get it in the 'off' position, and insert those wipers back as low as possible w/o traveling over the lower windshield trim. It took me several tries to get it perfect after tightening it up and testing...such small increments in that toothy arm-bolt.
trosty
26
Dec 18, 2022 06:40 PM
XJsc-guy
Sep 25, 2015 11:09 AM
joey g
US Northeast
Sep 7, 2015 06:28 PM
mcdutch
Sep 4, 2015 03:38 AM
XJsc-guy
Sep 2, 2015 11:43 AM
