wipers and light
Old Mar 12, 2012 | 05:34 PM
trooney968's Avatar
Default wipers and light
I have a 98 XK8 convertible. The windshield wipers will run on occasion by themselves sometimes stopping for a few seconds before returning. I have also had the lights, headlights and running lights turn off at night for a minute and then return to normal. I am thinking its a ground issue. Any help on this? Which ground if thats the problem.
Old Mar 13, 2012 | 10:13 PM
H20boy's Avatar
yikes, that's a tough one. I've never chased a ground, but there are a few on the car, to which one the lighting system is connected, I cannot direct you to. Hopefully, with a bump, someone else can chime in.
Old Mar 14, 2012 | 04:05 AM
jmarshall's Avatar
on the basis of the sign you have mentioned, i can switch that it signs the bad, damaged or loose Ballast.
Old Mar 14, 2012 | 04:05 PM
trooney968's Avatar
I ran it on a diagnostic machine and it came up with the internal park switch in the wiper motor is bad and should be linked to the lights issue. Im going to replace it and go from there. Thanks for responding I will update if it fixes the problem when I get it changed this weekend.
Old Mar 15, 2012 | 12:11 AM
H20boy's Avatar
We used to get small groups of 'wiper stalk' failures, so keep that in mind if you come up empty on the wiper motor, which I've never heard before.
Good luck on tracking it down.
Jpav27
Jul 31, 2022 06:43 AM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
mcdutch
Sep 4, 2015 03:38 AM
XJsc-guy
Sep 2, 2015 11:43 AM
