Won't go in gear, stuck in park
Old Feb 14, 2013 | 03:36 PM
spuddyo's Avatar
Default Won't go in gear, stuck in park
Hi Guys
I drove to work this morning, all OK no issues with the XK8. I have just jumped in it, car started OK but the gear selector won't fully engage in reverse ( although it will reverse if held there ) and I can't move the gear stick past reverse into Neutral or Drive. There are no warnings on the instrument pack.
Any idea what might cause this and is there a way around it. It feels like there is something stopping the gear stick from moving. The car is stuck on te carpark at work now.
cheers
Old Feb 14, 2013 | 03:52 PM
renaultvation's Avatar
Can you hear a click in the gear selector when you put your foot on the brake? If not, it could be the inhibitor (or whatever it is called) which prevents you from engaging drive without the footbrake on.
Old Feb 14, 2013 | 04:14 PM
spuddyo's Avatar
Smile
No click heard with brake on but the brake light works. I also checked the brake switches with an ohm meter and they work OK, so I'm thinking there may be a bad connection between the brake switch and the ECU/Transmission controller.
I looked on JTIS and it suggested removing the Torque screw by the gear lever and overiding the gearshift lockout solenoid. that worked, so I am on teh move again temporarily. It's a good job I have a sense of humour and another car or I would be in tears right now.
Thanks for you quick reply
Old Feb 14, 2013 | 06:22 PM
user 2029223's Avatar
Banned
On late model XJs and XKs there is a shift lever bracket on the left side of the transmission. This device is prone to losing a mounting bolt and jamming the shift lever. Very easy to find and fix if that is your problem.
I'm not positive your car is set up this way but I suspect it is. Check it out.
Old Feb 15, 2013 | 12:28 AM
XKRacer's Avatar
Un do the the plastic Torx screw on the J gate and put a small screw driver down there this will release the mechanism manually, take the screw driver out as soon as it moves
This is another typical brake switch problem
Old Feb 15, 2013 | 05:33 AM
spuddyo's Avatar
I followed jtis voltage checks on the brake switch, all seems ok so there may be a bad connection elsewhere. I have removed the lockout solenoid altogether now, problem gone.
Old Feb 16, 2013 | 02:01 PM
RCSign's Avatar
Last year I had a screw come loose from my sun visor, I screwed it back in, and pinched the wire to the vanity mirror and blew a fuse, I did not know it and I couldn't get to shift also. I don't have access to my JTIS to look a the wiring schematics but I believe one of the J-gate sensors is on the same circuit, I'll try to look it up when I get the chance. I believe it was in the drivers side fuse block on the dash
Old May 28, 2015 | 10:50 AM
DzJagXJ40's Avatar
Im having the same problem , But i do Hear a clicking noise on when i hit the breaks. What does this mean?
Old Apr 11, 2016 | 11:11 AM
Micalia's Avatar
Default Same problem with vidor, stuck in park
Hi I have had this same issue on more than one occassion. Screw loose, move visor to side...stuck in park. Took to mechanic, from forcing jgate in n out of park using the emergency unlock left of park, disengaging from p, something in jgate broke. Had fixed. Everything good...Until, I had husband replace my visor last night.screwed in..now... stuck in park, each time at start...have to manually disengaged with screw driver.. removed visor screws and can hear electrical working again. Did you find what fuse located on drivers dash where? Fuse or relay? Please help. Thnx
Rlover
Mar 30, 2016 10:04 PM
neruda
Oct 18, 2015 01:19 PM
chatmanx
Sep 11, 2015 07:17 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
