X100 Oil leaking from the torque convertor housing
Old Apr 9, 2020 | 09:18 AM
O&DR's Avatar
Default X100 Oil leaking from the torque convertor housing
Got oil leaking from the torque convertor through the lower access hole.
Assume the rear crankshaft oil seal or input shaft oil seal to the gearbox.
Cars a 1996 model with circa 80,000 miles and due an oil engine oil change.
Gearbox oil was changed circa 1,000 miles ago.
Any pointers or advise.
Assume this is a gearbox off job to fix, difficult or straight forward ?
Old Apr 9, 2020 | 10:39 AM
RJ237's Avatar
Transmission removal not particularly difficult, but you need a lot of ground clearance. Having a lift available makes it pretty easy. This would be a good time to replace the transmission A drum and pressure valve.
Old Apr 15, 2020 | 05:29 AM
johns55's Avatar
Not a hard job but it is time consuming. Decouple the driveshaft. Transmission cooler lines, shifter, and electrical connector off. Drop exhaust. Unbolt the transmission and remove. The Main rear seal looks like this.
Transmission out
A Drum replacement
Rear Main Seal
Ducmon
Feb 26, 2017 01:45 AM
Andrew5
May 14, 2015 11:45 AM
Takeo
Jun 26, 2012 10:37 AM
riz325
Dec 22, 2008 07:24 PM
