XK8 1999 air charge temp. sensor location
Old Jun 4, 2018 | 08:39 PM
Jag-CDN's Avatar
Default XK8 1999 air charge temp. sensor location
Hello,
I bought my brand new used xk8 and read 2 OBD-II codes P0111-P0112 which seems a faulty Air Charge Temp. Sensor. Not a cheap one. But my problem is, I can't identify its location. Your help will be appreciated.
Jean
Old Jun 5, 2018 | 07:27 AM
JagV8's Avatar
I often can find such things on parts diagrams online - worth a look?
Or the workshop manual - get it?
Old Jun 5, 2018 | 07:59 AM
fmertz's Avatar
Air temp sensor is built-in with the air flow meter, near the air box. Should be out in 2 min. You can try air flow meter cleaner spray. Double check the harness, too. Should be a DENSO part.
XJ8JR
Mar 2, 2022 10:08 AM
daytonaxj6
Nov 4, 2017 07:42 PM
ianritchie
Aug 22, 2017 12:15 AM
cobrawet2
May 30, 2016 05:20 PM
scoita
Jun 7, 2013 06:44 AM
