View Poll Results: Anyone experienced similar problems and fixed them ?
Diagnosed and fixed both issues
0%
Diagnosed and fixed ABS ASC TRAC issue
100.00%
Diagnosed and fixed trip computer reset issue
0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
xk8 200 asc abs warning plus trip reset
Old Jun 24, 2014 | 11:03 AM
Splash's Avatar
Default xk8 200 asc abs warning plus trip reset
XK8 2000
Getting the all too familiar ASC ABS Traction Control warning problem which seems to pop up after 2 to 3 hours driving depending on temperature.
On a hot day or after sitting traffic the warning lights appear sooner.
Stopping for an hour or so turns everything back to normal with no lights.
However another anomaly has just appeared which may/may not be related.
I normally drive with the MPG displayed on the dash and achieve ~25mpg
Whilst no warning lights were on, I sped away from a crawl and spun up a wheel or two a bit, as you do !
The Traction Control kicked in properly and the light blinked as expected, however the MPG display suddenly died and dropped from 25 to 19 instantly.
Checking the A & B trips, revealed these had reset and dropped from ~9,000 miles to zero. They then continued to clock up the mileage as normal mileage but counting up from zero, so lost the ~9,000 miles. The MPG has over time returned to ~25mpg.
I was considering undertaking the ABS unit dry joint repair job but I'm now wondering if the fault might be elsewhere.
Anyone had a similar experience or got any ideas please ?
My current plan is to put a heat shield around the ABS pump and maybe add a computer type finned heat sink !
Thanks Chris
99xk8guy
Sep 29, 2025 10:51 PM
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
mrplow58
Sep 9, 2015 11:27 AM
giandanielxk8
Sep 6, 2015 07:21 PM
