XK8 97' loose plug in engine compartment
Hello everyone,
I'm having some trouble with my bank 2 oxygen sensor reading 0 volts (thus failing the emission check, no wonder, if the fuel trim is at +20%), but while investigating I found this loose plug.
Does anyone happen to have any clue what's supposed to fit in it?
That looks like the connector to the EGR (exhaust gas recirculation) valve, on cars for the North American market.
I'm seeing this post on my phone at the moment, so I can't see what continent you're on!
Thanks for the help, that might also explain my exhaust problems!
I'm in the Netherlands and the car is a British import, is it at all possible that this was just left disconnected in European markets? That would seem rather strange though.
Found it, I think, according to this TSB it is possible to remove the EGR valve tube and connector:
http://www.jagrepair.com/images/TSB/...EGR%20Pipe.pdf
Though my VIN is not in the range, it mustn't be a problem then.
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
Sep 2, 2015 11:43 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
