XK8 clunking window
Old Mar 18, 2012 | 06:04 PM
tonytoller's Avatar
Default XK8 clunking window
When the window reaches the top of it's travel, I get a clunking sound like a cog is jumping a ratchet and I have to let go the switch because it sounds like something will break. I suspect I need a new motor, but can anyone confirm?
Because of this I can't reset the top and bottom points, so every time the door is opened the window drops further down and I have to remember to carefully wind it up again before I get out. Luckily it's the passenger window.
Thanks in advance.
Old Mar 19, 2012 | 06:59 AM
Did you check the FAQ's for Reverend Sam's videos? He has one troubleshooting a fault which sounds a lot like the one you describe:
Jaguar XK8 window adjustment. - YouTube
If you need advice on removing the door panel, he has another video covering this:
Jaguar XK8 Door Panel Removal. - YouTube
You don't say whether you have a Coupe or a Convertable but the window limit principle is the same for both.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
Razor
Aug 28, 2019 08:34 PM
British Ride
XJ40 ( XJ81 )
Nov 28, 2015 03:50 PM
picard
Sep 19, 2015 08:13 PM
