XK8 convertible top troubleshooting
Old Aug 15, 2017 | 11:53 AM
dwafford's Avatar
Default XK8 convertible top troubleshooting
Has anyone seen a troubleshooting procedure for the convertible top operation? I have the JTIS, but I can't find anything in it. When the ignition switch is turned on, the latch control valve and the top down relay are both energized and remain that way as long as the switch is on, but there is no movement. Pressing the top operation switch in either direction produces no results. Thanks for any help!
Old Aug 15, 2017 | 02:19 PM
oyster's Avatar
Here you have some info. Fault diagnostics at the end.
Old Aug 15, 2017 | 03:30 PM
dwafford's Avatar
Default Thank you!
This looks like it will provide everything I need to sort it out. Many thanks!
Old Aug 18, 2017 | 11:48 PM
Stamford's Avatar
Good luck! Please keep us informed as to what you find. The tops are overly complicated and can go bad in myriad ways. Always appreciate learning from others' misfortunes. ;-)
Old Aug 19, 2017 | 01:10 PM
willtoliv's Avatar
Mine had low oil level in the reservoir. Could not find any leaks. Checked the whole length of the hoses. I topped it up and it was fine for a few years, then it started slowing down. checked and fluid was a little low again. Mystery fluid! I added the resistor kit to lower hose pressure. That is a good idea. Do it before the "Green Shower".
Old Aug 19, 2017 | 03:24 PM
Gus's Avatar
Gus
Any luck in fixing the problem?
