XK8 Differential Fluid
Old Nov 20, 2016 | 09:12 PM
Gus's Avatar
Gus
Default XK8 Differential Fluid
I am so confused! I am having trouble finding the specs on the Differential oil for my 1999 XK8. What it calls for is Shell Spirax Super TS90 and I need to find the correct replacement.
Old Nov 21, 2016 | 03:31 AM
jamdmyers's Avatar
I purchased mine through the sponsor SNG, don't forget to note you are a member here is you do order through them, you'll get 10% off.
Old Nov 21, 2016 | 07:37 AM
Gus's Avatar
Gus
Thanks! I am not stuck on it being a Jaguar product I just need to know a replacement or the viscosity range of it calls for to see if I can get it locally.
Old Nov 21, 2016 | 09:24 AM
motorcarman's Avatar
ANY Synthetic 75W90 or 75W140 will work.
I use Valvoline or Mobile 1 Synthetic.
It's just diff oil.
bob
Old Nov 21, 2016 | 09:30 AM
Gus's Avatar
Gus
Thanks Bob! I was having a problem with finding the proper viscosity and did not want to under or over rate it.
It's just diff oil.
bob
