XK8 Differential Output Shaft Housing
Old Mar 26, 2020 | 02:27 PM
Bobster51's Avatar
Default XK8 Differential Output Shaft Housing
Does any have info on correct procedure for reinstalling the output shaft aluminum bearing housing into the differential. I would think the correct tolerance needs to be set to position the crown gear
Old Mar 28, 2020 | 06:46 AM
baxtor's Avatar
I have never had that housing out. I have done output shaft bearing changes but this is normally just circlip removal and shaft/bearing comes out leaving housing undisturbed.
Old Mar 28, 2020 | 10:46 AM
Bobster51's Avatar
Default Thanks
that seems to be a common repair, mine was leaking at the o ring around the outside of the housing. Believe these housings are to set back lash on the gear set
klfong
Sep 9, 2019 03:42 AM
Jagsandmgs
Feb 18, 2019 06:36 AM
baxtor
Jan 21, 2018 05:19 AM
philb1984
Aug 20, 2014 03:28 AM
cancer63
Feb 26, 2010 12:19 AM
