XK8 Fuel gauge problem
Old Jun 23, 2016 | 09:47 PM
Mogmichael's Avatar
Default XK8 Fuel gauge problem
My 1997 XK8 convertible's gas gauge always shows empty with "low fuel" warning light on. How can I test the system? Sending unit is accessible with a blk/wh wire and a Brn/wh one. Appears Blk/wh is the power lead. Can I jump between them to test or do I need a resistor?
Old Jun 24, 2016 | 07:39 AM
Gus's Avatar
Gus
See if this helps.
Link. http://www.jagrepair.com/FuelTankSendingUnit99XK8.htm
Gus
www.jagrepair.com
Old Jul 5, 2016 | 09:06 PM
Mogmichael's Avatar
Default Fuel Gauge issue
Finally got a chance to test the electrical for the fuel gauge. Used the JagRepair method, but only used one 470ohm resistor. That jumped the dash gauge off empty, cancelled the low level warning light and brought the gauge up to about 1/4 fuel level. Of course I refilled the tank just before finally determining that the sending unit was bad. Now just have to drive another 300+ miles and look for the replacement sending unit.
Thanks for the useful diagnosis help.
Michael
1997 XK8 convertible, 4.0L, BRG/coffee
1986 XJ6, sedan, 4.2L Silver/black
1967 Morgan +4 roadster, Green/black
BobRoy
49
Sep 18, 2016 10:48 AM
Don Elliott
May 11, 2016 11:17 AM
charliepace
Apr 23, 2016 04:29 PM
skubeedoo
Apr 21, 2016 01:40 PM
rolexslk2007
Apr 7, 2016 08:43 AM
