Fuel Pump Problem
Old 10-12-2012, 01:12 PM
Dark Cat's Avatar
Cool Fuel Pump Problem
Hello: Can anyone tell me how to drain the fuel from my 2000xk8 fuel tank? My fuel pump quite and I have the tank ready to remove.
I cannot get a hose to enter the tank from the filler, I am using a 1/2" inch hose and it will not go all the way in the tank.
I have looked and cannot see any drian plugs?
Old 10-12-2012, 03:00 PM
RCSign's Avatar
I had a rough time when I replaced my fuel pumps. Your suppose to be able to run a siphon hose through the tank filler neck I could never get it through. I removed my fuel lines and took a 10MM socket head bolt with O rings and pushed it into the connector on the tank that stopped the fuel from running out. Then I was able to maneuver the tank around until I could remove the access cover on the tank so I could siphon the fuel out.
Dark Cat (10-12-2012)
Old 10-12-2012, 03:36 PM
Dark Cat's Avatar
Okay thanks I will figure out some thing I was hoping someone had a trick to getting the hose to enter the tank.
Old 10-12-2012, 09:23 PM
Dark Cat's Avatar
Doug: Just thought you would want to know
To drain my fuel tank I found by removing the fuel filter which I had to replace any way so I connected a pump to the feed line to the filter and drained the tank.
I worked great.
RCSign (10-14-2012)
toronadomike
08-07-2022 03:41 PM
Sprayall
05-30-2021 08:13 AM
Charlene n John
09-28-2015 06:01 AM
Charlene n John
09-06-2015 11:03 AM
Sprayall
09-03-2015 07:49 PM
Quick Reply: Fuel Pump Problem
