Xk8 parking light problem
Old Apr 24, 2017 | 08:37 AM
02jagstype's Avatar
Default Xk8 parking light problem
Hello and thank in advance for any help. I installed a Garmin Navi in my 98 xk8 yesterday I used the accessory plug behind glove box for power. Today I noticed my parking lights front and rear are both not working. I check fuse 19 and 21 in the trunk but they were both good. Any idea what to check next ? Everything worked fine before I installed the Navi. I don't believe I was anywhere near any other wiring besides the accessory plug behind glove box and installing the relay in trunk fuse panel to make it work. Thanks
Old Apr 24, 2017 | 10:45 AM
02jagstype's Avatar
Just noticed the front and rear fog lights also aren't working.
Old Apr 24, 2017 | 05:00 PM
02jagstype's Avatar
Default Please help!
Update , checked all the fuses. Everything was good. Not getting power to fuse 19 or 21 in trunk fuse box. Any ideas would be greatly appreciated..
Old Apr 24, 2017 | 05:11 PM
michaelh's Avatar
Check F7 (15A) in driver side fusebox (end of fascia) and F17 (15A) passenger side fascia fusebox.
Mike
Old Apr 24, 2017 | 05:20 PM
02jagstype's Avatar
Just checked both fuses and checked to see if power was going to them . They both checked out good
Old Apr 24, 2017 | 05:37 PM
michaelh's Avatar
Mmm.
BPM controls all the functions you have lost & has separate fuses for logic & lighting. Sounds like the latter are OK so - possibly you disturbed something in the dash? BPM is on pass side for LHD.
Old Apr 24, 2017 | 05:40 PM
02jagstype's Avatar
Default Update
I pulled the lamp control module off to inspect. Here is what I found, it looks to me as the brownish colored resistors are burnt? Could this be my issue?
Old Apr 24, 2017 | 05:45 PM
michaelh's Avatar
All looks pristine.
Rear fog power doesn't pass through the LCM, and it wouldn't explain your loss of front lighting.
If you're not getting power to the trunk tail lamp fuses then the relay isn't firing - controlled by the BPM.
Mike
Old Apr 24, 2017 | 05:49 PM
02jagstype's Avatar
Bummer I was hoping that was it. It looked to me like d1 ,d2,d3, d4 and zd2 were all burnt. What's the best way to determine if it's a bad bpm?
Old Apr 24, 2017 | 05:57 PM
michaelh's Avatar
No, the diodes look fine!
BPM not necessarily faulty - there's a large 104-way plug on it that might have come partly out of place.
I've never delved that far under the dash on mine so I don't know its exact location. You might try unplugging and re-seating the connector, but do disconnect the battery first...
Old Apr 24, 2017 | 06:00 PM
02jagstype's Avatar
Thanks I will check that out real quick and report back
Old Apr 24, 2017 | 06:12 PM
02jagstype's Avatar
Unplugged the battery , pulled the glove box and checked the bpm and everything else around it and it all looked fine. Unplugged and replugged the bpm and made sure the 10mm bolt was tight.
Old Apr 24, 2017 | 07:28 PM
michaelh's Avatar
Hard to believe that the BPM would have got damaged by adding a relay in the trunk. There is a connector (LF1) that all the feeds to the front lighting pass through, but that doesn't explain the missing rears.
I was thinking that something got disturbed:- usually when something breaks after last job done then revisit that job LOL
I've re-checked JTIS to see if I've missed anything. Not entirely helpful I'm afraid, but I'd break out the multimeter and check continuities - particularly around power for the BPM before condemning it. Do you have the wiring diagram for the '98? - it's on Gus' oracle:
http://www.jagrepair.com/images/Auto.../jagxk1998.pdf
and probably in the stickies.
I'll take a fresh look tomorrow (it's 1:30 AM here) and report back.
Good luck,
Mike
Old Apr 24, 2017 | 07:33 PM
02jagstype's Avatar
I just found the problem moments ago. After alot of testing and head scratching. I finally checked the headlight switch/ turn signal lever by removing the lower steering wheel trim piece. As soon as I took it off I noticed a loose green wire. I touched it to the spot it had come unsoldered from and everything lit back up! Tomorrow I will remove the steering wheel and stalk and get everything soldered up. Thank you so much for your time and all your help.
Old Apr 24, 2017 | 07:52 PM
michaelh's Avatar
Brilliant. I love the $0 fixes!
Sorry I didn't actually help in the end, but please expand on what you did once it's all buttoned up.
Mike
Old Apr 24, 2017 | 08:18 PM
02jagstype's Avatar
Default Problem solved
I found this person having the exact same problem and followed all the directions which led me to the turn signal stalk. Now all my lights including front and rear fog lights are all functioning as they should. http://www.justanswer.com/jaguar/6dwek-tail-lights-not-working-work-fine-put-power.html
Old Apr 25, 2017 | 07:43 AM
michaelh's Avatar
o2,you have a really cunning resident Jaguar gremlin.
He's thought "He he - busy under the dash so I'll just pull this wire off the light stalk. He'll never notice and it will confuse everyone and he'll get the blame for breaking something"
The fogs, of course, won't work because the BPM inhibits them unless the sidelights are on.
I'm sure someone posted a write-up on stalk R&R recently - possibly Johnken.
Glad you got there so quickly.
Mike
