XK8 - passenger seat
Old Mar 4, 2015 | 05:24 AM
jhennigar1's Avatar
Default XK8 - passenger seat
I have a beautiful bright red XK8. The passenger seat will lift the headrest and lumbar, but will not move up, down or forward or reverse. I am told Ford makes a control that will solve the problem. Any other suggestions? Thanks.
Last edited by GGG; Mar 4, 2015 at 08:25 AM. Reason: remove personal email address
Old Mar 4, 2015 | 08:23 AM
I've moved your question from Off Topic to XK8/XKR forum. Members here with the same model will be able to help.
You should add Model and Year details for your vehicle.
Old Mar 4, 2015 | 08:35 AM
test point's Avatar
The seat control module is famous for failing. You can swap with the driver's seat to verify the fault. Common problem is that one or more of the printed lines on the circuit board is broken.
There is a technician doing repairs on the units in Southern CA. See: https://www.jaguarforums.com/forum/x...working-27096/
As far as the Ford seat module the Jaguar one says FORD on the case and I had a Lincoln with a module that looked exactly like my non functioning XK8 but it wouldn't work. Apparently close, but no cigar.
Old Mar 5, 2015 | 08:51 AM
jhennigar1's Avatar
This was very helpful, Thank you.
JeffinSwitz
Sep 16, 2015 01:44 PM
diablomkii
Sep 14, 2015 02:37 PM
avern1
Sep 8, 2015 06:25 PM
joey g
US Northeast
Sep 7, 2015 06:28 PM
bdboyle
Sep 4, 2015 06:16 AM
