XK8/R Bluetooth Wiring Harness
Old Feb 9, 2015 | 06:10 AM
redpoptop's Avatar
Default XK8/R Bluetooth Wiring Harness
Hi,
I am hoping someone with some knowledge of the 2005 Factory Bluetooth wiring may be able to help.
I am trying to find a circuit diagram of thefor the wiring harness of the XK 8/R 2005 MY factory Bluetooth cellular phone modules for the PSE unit to the BTU
I can find the GSM version but not the Bluetooth version regarding the XK8 / R Series.
Was a diagram ever published?
Redpoptop
Old Feb 9, 2015 | 07:55 AM
ccfulton's Avatar
I am sure it was published but I think that the method jaguar used to publish the service manual changed in 2004 so those are the latest that are easily available for free.
The vehicle connections are the same though so the connections that go outside the dotted "phone" box in the diagram are correct.
Maybe if you elaborate more on what you are trying to do/solve someone can help more specifically.
Old Feb 9, 2015 | 01:52 PM
The harness terminating in the blue connector to the PSE?
XK8/R Bluetooth Wiring Harness-dsc_0090.jpg
I have the 2003-06 XK8/XKR Workshop Manual which superseded JTIS but there's no Bluetooth circuit diagrams in it.
Old Feb 10, 2015 | 02:47 AM
redpoptop's Avatar
Hi
I am looking for the PIN configuration for the wiring harness from the PSE to the Arm rest so that
I could replace the fixed Jaguar / Motorola 8900 hand set over to the Jaguar Bluetooth system
Which I have the BTU & PSE units.The vehicle is pre wired for BT but I cannot get the BT wiring harness that connects to the PSE - BTU/ICE unit.
So I through about rewiring the current GSM harness and use that.
Redpoptop
Majik Lasers
Aug 2, 2024 01:49 AM
perezal
Dec 24, 2015 04:56 PM
perezal
Dec 24, 2015 04:18 PM
SeanU
Sep 14, 2015 04:31 PM
tvholden
Sep 12, 2015 11:13 AM
