Xk8 rear subframe drop
Old Nov 23, 2014 | 04:11 AM
xk8forlife's Avatar
Default Xk8 rear subframe drop
Hello, I need to drop my xk8 rear subframe since I just suffered an accident and one part of it is bent. Can I pull out the rear subframe on my driveway with jack-stands etc... or do I need to get a 2 point hoist? Also what are the chances of the wishbone bending? Thank you
Old Nov 23, 2014 | 05:12 AM
scoobie's Avatar
Hi - sorry to hear about your accident.
I removed my rear subframe using axle stands and a cheap trolley jack.
Job would have been dead easy if it hadn't been for one of the a-frame bushes refusing to part company with the chassis pin!
I jacked mine up just under the diff using a block of wood to prevent damage.
Put 2 x 3 ton axle stands under the rear jacking points.
Undid all the bolts (see JTIS), handbrake etc.
undid the rear exhaust rubbers
Dropped the suspension down enough to squeeze my arm and a 10mm rachet to undo the top exhaust mounts.
Dropped it down on the trolley jack.
I'm just in the process of stripping it to paint everything.
Some photos here - https://www.jaguarforums.com/forum/x...-127865/page2/
Good luck
Mark
Old Nov 23, 2014 | 12:58 PM
xk8forlife's Avatar
Yeah it's a real bummer. I'm glad to hear that I can fix it thou and take it to a garage. Thanks for the help!
Old Nov 25, 2014 | 08:57 PM
aode06's Avatar
if it applies to you, try to recall/remember the alignment settings/shims etc that might apply
99xk8guy
Sep 29, 2025 10:51 PM
FrickenJag
Jun 16, 2025 02:15 PM
bamforp
Aug 14, 2024 05:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
RaceDiagnostics
Sep 7, 2015 07:28 AM
