XK8 Replacement Bushings
Old Feb 26, 2011 | 08:38 PM
Mish_Mish's Avatar
Originally Posted by Goldlion
Mish: are those upper bushings from PowerFlex? I am planning to install PowerFlex on my XKR and was wonder how you have fond the handling and ride quality to be?
Yes they are and after driving car for the first time tonight, I am very pleased. Absolutely no new vibrations, or any other unpleasantness.
Suspension feels little tighter and steering wheel is now in the dead center, when before it was a little to the side.
Also, it looks like bushings I took out of my car were almost new, or in perfect shape. I should probably eBay them
Old Feb 27, 2011 | 12:30 AM
XK8+XJ8L's Avatar
Default You Guys Amaze Me!!
Hopefully, I'm a few years away from this exercise, but I'm following it with interest. Every day I seem to find another reason to love this forum. When you look at the amount and quality of information flowing in this thread, it is incredible. Not to mention the willingness of all involved to share their experiences (for better or worse) so the next guy will have it a little easier. When my day comes to tear into the front end, I'll bet this thread will be a valuable resource. Thanks in advance.
Cheers,
Old Feb 28, 2011 | 12:02 AM
H20boy's Avatar
Originally Posted by charliepace
Be nice to meet you sometime
subscribe to the regional section of the forum, and look for a meet that should be happening soon...and will be happy to properly introduce myself.
Old Jun 11, 2011 | 02:42 PM
Badkitty's Avatar
Just replaced one bushing with the help of my neighbors who are all good backyard mechanics. The front one on the lower control arm was cracked causing a lot of vibration. I'm going to do the other side tomorrow. The only hard part was getting the bushing out of the lower arm bar. I rented the tool to press the new bushing in, but it still required some hammering to get it fully seated. I went with the Jaguar oem rubber ones. I'll let you know how they feel once I test drive it.
Sorry I don't have a video camera or I would try to video the other side. Thanks to all who have posted to this thread. I would have never had the confidence to take this on otherwise.
Old Jun 12, 2011 | 07:15 PM
Badkitty's Avatar
Old Jun 12, 2011 | 07:36 PM
Badkitty's Avatar
Default Replacing the front forward lower control arm bushing
I was able to take some photos as we repalced the second bushing. The car is smooth as silk now short of a little alignment issue. The bushings cost me $35 each and the whole job took about 4 hours....3 for the first side and 1 for the second. I hope these photos will shorten the learning curve for anyone who wants to give this a go.
The first two photos show the two parts that need to be removed to make room for removing the control arm.
Name:  Support strap bolt.BMP
There's that bracket that goes across the underside of the car
Name:  Plastic cover.BMP
and the plastic piece that goes across the front of the car.
Name:  76-015 tool for removing control arm.BMP
This is the star tool needed to remove the two bolts that connect the control arm to the chassis. It's a 3/8 inch drive star tool...part number 76-015.
These are the two bolts before we disconnected them. We found that a good dose of WD 40 was essential to loosening those bolts. We also used a heavy duty ratchet.
Name:  Bushing on the car 2.BMP
This is the bushing as it is attached to the car. The left of the photo is toward the front of the car.
This is the bolt that goes through the bushing that has to come off. So, in all, there are only three bolts to remove once the tire is removed from the car.
Name:  Worn bushing in the control arm.BMP
You can see how worn and dry the bushing is in the removed control arm.
Name:  Burning out the bushing.BMP
We actually had to burn the crap out of that bushing and pound it like crazy to remove it. There is a machine to do it but we did not have access to one.
Name:  C clamp tool for inserting new bushing.BMP
Name:  C clamp tool for inserting new bushing 2.BMP
The last two photos show the C clamp tool we rented from Auto Zone to press the new bushing into the lower control arm. We learned, after struggling a lot with the first one, that a good dose of grease and some patience to hammer the bushing in part way before torking it in with the C clamp tool, made the job much easier. The issue we had was that the clamp wasn't big enough to accommodate the bushing, the control arm, and the top and bottom pieces of the clamp, so by getting the bushing partially inserted, we could fit the whole mess in the clamp and tork it down. We had to stop periodically and tap the edges of the bushing to keep it straight as it went into the opening in the lower control arm.
Once the new bushing was in the control arm, everything went back together very easily.
Old Jun 13, 2011 | 12:09 PM
H20boy's Avatar
good job, and thanks for the pics!
toronadomike
Jan 22, 2026 10:13 PM
kelliott
May 31, 2022 05:26 PM
David Thompson
Sep 3, 2015 07:48 PM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
