XK8 transmission problem
Old Oct 18, 2012 | 10:57 PM
ai817's Avatar
Default XK8 transmission problem
I have a 99 Jaguar XK8 and I'm getting a transmission fault. I hooked it up to the code reader and I have codes P-0455, P-1000, P-1722, P- 1737. Can you help me out?
Old Oct 19, 2012 | 07:52 AM
Gus's Avatar
Gus
P0455 is a fuel vapor leak and is often caused by your gas camp not seated properly.
P1722 is Transmission stall speed failure and this could be a number of things from fluid level low, selector cable adjustment, speed sensor or the typical mechanical failure that is often the “A” & “B” drum failure.
P1737 I am unable to address it. Did you get the correct number?
Sounds like you need to get the transmission checked.
Old Oct 19, 2012 | 09:17 AM
steveinfrance's Avatar
Welcome to the Forum ai817.
I've started a new thread for you since the other is two years old and not entirely relevant.
Please visit
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and introduce yourself so we can say 'Hello'
Old Oct 20, 2012 | 12:40 PM
ai817's Avatar
Thanks Gus. P-1737 lock up solenoid system. What could that be?
toronadomike
Jan 22, 2026 10:13 PM
99xk8guy
Sep 29, 2025 10:51 PM
RoyLittle0
May 25, 2023 02:38 AM
XJsc-guy
Sep 25, 2015 11:09 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
