XK8 trunk lamps
Old Mar 20, 2024 | 06:39 PM
beefheart's Avatar
Default XK8 trunk lamps
Hello Jaguar fans, I have a 1998 XK8 roadster, I have a problem with my left and right trunk lamps. I do have fresh new bulbs, and when I use my test light , power to the lamp assembly , but the lights don’t work, any suggestions? Thank you!!
Old Mar 20, 2024 | 09:00 PM
motorcarman's Avatar
I don't think you understand how DC current works. You need POWER and EARTH. (ground)
Measure BOTH sides of the lamp and make sure you have POSITIVE and NEGATIVE supply as well as a good festoon bulb.
Old Mar 21, 2024 | 02:47 AM
John Oak's Avatar
Hello Beefhart,
the BPM (body processor module) provides the +12V to the lamps: Thhis is what you may measure. It will stop providing this after a set time in order to stop draining the battery if the boot is open
in line with the lamps is a little switch located in to trunk/boot lock. This is in fact a very tiny microswitch that has a tendency to break.
If you (double) lock the car with the remote control and then open the boot with the manual key, the alarm should be activated: If not, this switch is broken
(In my case it was "half dead": Providing a too high resistance - it was still giving enough ground to the SLM (security and lock module) to inform it, that the boot is open) but the resistance was too high for the lamps to be "on")
There is plenty of info on this switch within this forum...
Regards, Johannes
Old Mar 21, 2024 | 06:50 AM
beefheart's Avatar
Thank you , will check these helpful tips out , appreciate it!!
Old Mar 28, 2024 | 06:48 AM
beefheart's Avatar
found out the micro switch on the latch was faulty, replaced it yesterday and all is good to go, thanks again for the help!
garycs
Nov 24, 2017 01:36 PM
hirev
Mar 2, 2017 08:44 PM
IcyBlueRose
Feb 20, 2015 06:07 AM
wjd03
Jan 17, 2011 08:27 AM
