XK8 window
Old May 3, 2014 | 03:07 AM
maringa's Avatar
Default XK8 window
When I open the driver's door on my 1996 XK8 convertible the window drops a couple of inches. Lift the door handle again and it drops another couple of inches. Has anybody had this (minor) problem and knows how to fix it?
Otherwise a great car I bought from the original owner and I love it.
John
Old May 3, 2014 | 05:07 AM
graham11's Avatar
hi,to reset your windows,press your down switch and hold till you hear a slite clicking sound,then press up and hold till you hear the same sound,your windows should then be reset,do this with your doors closed,your windows should then drop slighty when you open your doors again,do the same on both sides.
Old May 3, 2014 | 07:10 AM
WhiteXKR's Avatar
....and if the problem comes back again your battery is either low and needs a charge or it needs to be replaced.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
GordoCatCar
Jan 2, 2017 01:10 PM
rentzoo
Nov 10, 2015 04:56 PM
picard
Sep 19, 2015 08:13 PM
