XKR convertible roof creaking
Old Nov 4, 2017 | 06:22 PM
Jagman46's Avatar
Default XKR convertible roof creaking
Hi, the roof of my convertible is creaking when closed. It seems like the noise is coming form the front of the roof. Is there any adjustment that can be made to pull the roof down tighter to stop the creaking.
Old Nov 4, 2017 | 08:39 PM
Gus's Avatar
Gus
Have you had any work done on the header like a hose replacement?
Old Nov 5, 2017 | 07:24 AM
Jagman46's Avatar
Hi Gus. I have only recently purchased the car but knew the previous owner quite well and have all his bills etc. for work done and am not aware of any such work having been done.
Old Nov 5, 2017 | 07:37 AM
Gus's Avatar
Gus
If the hose or the latch ram were replaced it could be that the rack for them was not aligned properly or is loose. You need to find out if any work was done.
Old Nov 5, 2017 | 09:11 AM
Jagman46's Avatar
Thanks Gus. However it is sad to say that the previous owner died one week ago of lung cancer, so unfortunately I will not be able to find out if anything has been done
Old Nov 5, 2017 | 09:47 AM
Gus's Avatar
Gus
Your best bet is to remove the interior covering for the header to see if the bolts are loose or need readjusting.
Old Nov 6, 2017 | 08:28 AM
Jagman46's Avatar
Thanks Gus,
I'll see what I can do, although it may be a while as I am holiday soon.
