xkr Coolant crossover and SC bypass O rings???
Old Mar 27, 2016 | 07:50 PM
XxSlowpokexX's Avatar
Default xkr Coolant crossover and SC bypass O rings???
Where can I get these? Any part numbers? Also I cant seem to find coil cover gaskets anywhere..Mine are non existent. Thanks!
Old Mar 27, 2016 | 09:33 PM
TexMurphy's Avatar
I think the xk8 and xkr have the same water outlet pipe / crossover if that is what you are talking about. If the same as my 97 they come in the crossover tube. Mine was leaking due to reused seals by PO mechanic and some stress cracks due to two bad engine mounts, and if was going to take it off I would consider just buying new pipe as it is a point of failure, and comes with new temp sender. SNG was about $40 plus shipping, they do sell the gaskets separately for about $3 each. You should be able to get them through WorldPac special order at many autoparts stores AdvanceAutoParts, CarQuest and more as other online stores.
I think the coil covers are a replace entire thing no gasket as it is a formed to cover at factory type thing. My car had one missing and I used a piece of peel and stick foam weather strip trimmed to about 1/4 inch wide as I didn't want sand falling in cover as I found when recently removing mine. The covers are surprisingly low price to replace if you want to go that way. I opted to make mine work for now even though missing one corner on each as it is an easy replace at later point type of part.
Old Mar 27, 2016 | 10:50 PM
I have a metal crossover pipe already. Ill see if I can get those o rings. I just cant find the part # anywhere. As for the coil covers mine are custom and although cheap enough to buy new ones I like the carbon fiber look I got going. I think Im going to use silicone. Silicone and some painters tape and it will be neat, or..maybe a foam tape:O)
Old Mar 28, 2016 | 08:49 AM
TexMurphy's Avatar
Are you talking about AJ85785 pipe or something else? Didn't know there was a metal option.
Go to SNGBARRAT.COM and download parts pdf. Very helpful when trying to locate part numbers. Good puctures and part numbers for different years and models.
Old Mar 28, 2016 | 07:38 PM
The attached photo. Ill Download that catalog and see what I can find
Attached Thumbnails xkr Coolant crossover and SC bypass O rings???-img_5205.jpg
Old Mar 28, 2016 | 08:10 PM
TexMurphy's Avatar
SNG Barratt - The Ultimate Jaguar Parts Specialist
Looks like although the water pipes are different on our two cars the gasket is the same.
Old Mar 28, 2016 | 09:44 PM
Yah I do believe I found the proper gasket. Its not really clear at all took me a long time to figure it out. If its correct when it arrives Ill post the part number
DanCiprian
Mar 27, 2016 11:38 PM
XxSlowpokexX
Mar 27, 2016 09:54 AM
XxSlowpokexX
Mar 25, 2016 07:07 PM
jackra_1
Mar 24, 2016 11:35 AM
TexMurphy
Mar 22, 2016 08:10 PM
