XKR Factory Alignment Specs Needed For Proper Up To Date Alignment The Way It Should
Old May 9, 2010 | 10:36 PM
jagxkrtoofast's Avatar
Banned
Arrow XKR Factory Alignment Specs Needed For Proper Up To Date Alignment The Way It Should
So I am going in for an alignment and I would like the correct data that's needed to fulfill the proper factory specs for an XKR. Thanks
Old May 10, 2010 | 08:22 AM
attaboy's Avatar
what year? The shop we have here (we have only one) has a 2yo computerized rig .. I will be putting my xk8 into it shortly .. for drill .. and to diagnose some road noise .. we hope. Give me the year, and I'll havem' punch it up and post it for you.
Old May 10, 2010 | 08:34 AM
Brutal's Avatar
the specs have never changed for XK's only Stype's. And having the latest most up to date software and machine does NOT matter. Our software from Hunter was just changed and still has incorrect Stype specs. I go in and manually enter, change, and save the correct specs. Whatever they have Im sure is correct, now wether or not they know what they doing with them is something different entirely
Old May 10, 2010 | 08:41 AM
H20boy's Avatar
Brutal and the other techs always recommending starting with the factory specs (you'll find them in the Jaguar Specification Document in our FAQ sticky at the top of these forums to download), then 'load' the suspension to take any account for typical vehicle toe gained by moving forward, then readjust back into spec. Most regular shops won't load it, then when you end up driving it, the wheel ends up too far toe-d out, resulting in additional inside tire wear. (more from just a little negative camber that our cars 'settle' into over the years.)
Old May 10, 2010 | 08:42 AM
H20boy's Avatar
brutal...good timing! You should be finishing your third cup of coffee by now, getting ready for your day.
Griffbritgreen
Jul 27, 2016 05:43 AM
detXJ
May 22, 2016 10:50 PM
TC Johnson
Aug 29, 2015 08:55 PM
Jandreu
Aug 29, 2015 07:31 PM
divingmom
Aug 25, 2015 07:54 PM
