XKR MAF replacement
Old Mar 17, 2014 | 06:33 AM
kreyszig's Avatar
Default XKR MAF replacement
Hi
Just hoping someone can recommend a good source for an MAF sensor. I have a leak but if I can get a replacement (new) MAFS cheap enough I might try swapping it to see what happens.
Part number for my VIN is LNE1620BB
SNG Barrat have it for £140, just wondering if theres an aftermarket or ford etc. part I can use. Theres loads of XK8 versions on ebay for around £40, but I can't see one for an XKR
Thanks in advance!
Old Mar 18, 2014 | 09:51 AM
You're right - these are hard to find!
Try this link:
Jaguar MAF Mass Airflow Meter LNE1620BB XJR XKR
This is supposed to be an aftermarket equivalent to LNE1620BB at £50.
Old Mar 18, 2014 | 10:23 AM
RaceDiagnostics's Avatar
Before buying a new MAF do a WOT run and measure your peak g/s reading, then ask around here for a comparison for another 4.0 XKR.
Old Mar 18, 2014 | 10:33 AM
kreyszig's Avatar
thanks very much both!
Will take a reading tonight and post back
Old Mar 19, 2014 | 06:47 AM
kreyszig's Avatar
Right my peak value wasn't at 100%, it was 216.7 at 62% throttle
At 100% throttle I have 9 values (couldn't keep it at 100% for long!):
190.96
176.08
169.31
167.79
160.9
156.19
154.74
148.58
108.52
At low throttle my values are around 4.8-5
Hows that looking? Thanks for your help so far!
Edit: Note that these are not in time sequence, I hit the throttle a couple of times and these are just the ones at 100% throttle sorted max->min
Old May 19, 2014 | 10:28 AM
turbo68's Avatar
Dont mean to hijack this thread but title is what I was looking for.
I am wanting to replace my MAF Sensor and wondered if the ebay one here if fine for replacement.
Mass Air Flow Sensor MAF for Subaru Impreza Forester 2 0L 2 5L 22680AA310 | eBay
I have tried to clean min with CRC cleaner but it still happens from time to time. Actually...when i removed the unit the o-ring was not in the best of shape. So if someone knows where I can get that size of o-ring that would help too.
Thanks in advance
toronadomike
Jan 22, 2026 10:13 PM
Beardy
Sep 18, 2015 10:00 AM
tberg
Sep 7, 2015 07:32 AM
OkieTim
Sep 2, 2015 12:48 PM
TC Johnson
Sep 2, 2015 09:30 AM
