Gurgling noise from behind dash.
Old 10-27-2020, 09:18 PM
Scotlad's Avatar
Default Gurgling noise from behind dash.
I bought a 2005 S type R about 4 months ago and so far so good. One thing I have noticed is when I turn the engine off after I have been driving for a while I hear what sounds like a faint gurgling from behind the dash more on the passenger side. Is this air in the coolant or something else I should be concerned about?
Old 10-28-2020, 06:46 AM
joycesjag's Avatar
Received 1,692 Likes on 1,208 Posts
Normal, there are many threads to explain why it happens.
Welcome to the forums!
Old 10-28-2020, 09:28 AM
davidladewig's Avatar
I've never heard a gurgling noise. Sounds haunted.
Old 10-28-2020, 10:17 AM
kr98664's Avatar
Received 1,985 Likes on 1,402 Posts
I'd suggest getting out of the car more quickly or turning up the radio if you plan to sit a while. That should take care of it.
All seriousness aside, is the coolant level okay? If low, you may get some air in the heater lines. Does the heater and AC work okay? If the coolant level and HVAC operation are okay, I wouldn't worry about a faint noise after shutdown. There's an official bleeding procedure for the cooling system, but it's something of a pain. Usually just normal driving of the car purges the air from the lines. If you haven't been driving much, or just babying the car, the air may not have fully cleared itself. If still concerned, you can always do the full bleeding.
The following 2 users liked this post by kr98664:
davidladewig (10-28-2020), Scotlad (10-28-2020)
Old 10-29-2020, 01:07 PM
JagLover2006's Avatar
Default Behind Dash Sounds
This is likely the actuators attached to the louvers of the ducts that are part of the heating and cooling system stuck in a cycle of opening and closing repeatedly. It's a known fault and dealers got a shop notice on this for 2004 to at least 2006 S-Types to recall and repair at dealers expense. I had to fight with my dealer but they finally relented and replaced the faulty parts at their expense, including labor. Best of luck.
The following 2 users liked this post by JagLover2006:
Jules88 (12-17-2020), Scotlad (10-29-2020)
manny559
10-29-2020 01:10 PM
Sue Pete Wentworth
09-09-2019 10:26 PM
otherman
02-07-2016 02:06 PM
Joliver
12-02-2012 03:54 PM
jam1white
10-19-2011 03:04 PM
Quick Reply: Gurgling noise from behind dash.
