Gurgling noise from behind dash.
Old Oct 27, 2020 | 09:18 PM
Scotlad's Avatar
Default Gurgling noise from behind dash.
I bought a 2005 S type R about 4 months ago and so far so good. One thing I have noticed is when I turn the engine off after I have been driving for a while I hear what sounds like a faint gurgling from behind the dash more on the passenger side. Is this air in the coolant or something else I should be concerned about?
Old Oct 28, 2020 | 06:46 AM
joycesjag's Avatar
Normal, there are many threads to explain why it happens.
Welcome to the forums!
Old Oct 28, 2020 | 09:28 AM
davidladewig's Avatar
I've never heard a gurgling noise. Sounds haunted.
Old Oct 28, 2020 | 10:17 AM
kr98664's Avatar
I'd suggest getting out of the car more quickly or turning up the radio if you plan to sit a while. That should take care of it.
All seriousness aside, is the coolant level okay? If low, you may get some air in the heater lines. Does the heater and AC work okay? If the coolant level and HVAC operation are okay, I wouldn't worry about a faint noise after shutdown. There's an official bleeding procedure for the cooling system, but it's something of a pain. Usually just normal driving of the car purges the air from the lines. If you haven't been driving much, or just babying the car, the air may not have fully cleared itself. If still concerned, you can always do the full bleeding.
Old Oct 29, 2020 | 01:07 PM
JagLover2006's Avatar
Default Behind Dash Sounds
This is likely the actuators attached to the louvers of the ducts that are part of the heating and cooling system stuck in a cycle of opening and closing repeatedly. It's a known fault and dealers got a shop notice on this for 2004 to at least 2006 S-Types to recall and repair at dealers expense. I had to fight with my dealer but they finally relented and replaced the faulty parts at their expense, including labor. Best of luck.
manny559
Oct 29, 2020 01:10 PM
Sue Pete Wentworth
Sep 9, 2019 10:26 PM
otherman
Feb 7, 2016 02:06 PM
Joliver
Dec 2, 2012 03:54 PM
jam1white
Oct 19, 2011 03:04 PM
