replacing the r badge
Received 12,737 Likes
Once the emblem is removed, use a combination of low heat (a hair dryer is safer than a heat gun), a fingernail or small plastic scraper, and a mild solvent like 3M Adhesive Remover to remove the tape residue.
To help the new emblem adhere well, wipe the body with wax remover or denatured alcohol and allow to dry before pressing the badge into place.
Cheers,
Don
anthawk - fyi i picked up some of those knock off badges on eBay for $4 a pop. they come in a nifty little ziplock sack, with backing double sided precut tape and they have two little flanges in the back where you could install a couple of mounting bolts. Only drawback is that the back side is not flat but concave.
http://www.ebay.com/itm/272410506528...%3AMEBIDX%3AIT
