Directional/Blinker chime or noise
Old 09-12-2014, 03:24 PM
Spikepaga's Avatar
Default Directional/Blinker chime or noise
Hello men!
I have been so caught up on expressing my distaste/disdain of the Jaguar XE that I forgot I have a pressing issue to take care of in my now even more beloved X type!!!
Does anybody know if there is a speaker in the steering wheel column? I get no sound from my flashers and find myself running all over town with the blinker on, and it sounds like the XK8's have a little speaker in the steering wheel for the "blinker noise" can anyone tell me before I take the steering column apart?
Thanks!!
Old 09-12-2014, 07:52 PM
Thermo's Avatar
Received 3,826 Likes on 3,145 Posts
Spike, the audible clicker is mounted inside the turn signal stalk. So, you will need to pull apart the steering column and find the box for the turn signal stalk. With this being said, you can probably find a new pizo electric piece to put in there to change the sound of the clicker should you so desire. It should be a simple 12 VDC signal for the clicker. Worst case, put a multimeter across the "speaker" and see what it reads. I am sure you could find some interesting sounds to put in its place.
Old 09-13-2014, 05:32 AM
Spikepaga's Avatar
Well that's great to know. For a moment there I thought the turn-signal noise was supposed to come from either the body processor module or the speakers themselves..... Basically I need to get a new turn-signal switch
Thanks!!
Old 09-16-2014, 06:05 PM
Spikepaga's Avatar
Well taking the signal stalk out of the steering column took me less than five minutes, however I was unable to take it apartto get to the speaker inside since all sorts of tiny parts would have come out flying in pieces.
I guess a new one is the only way to go
JimC64 (09-16-2014)
Old 09-16-2014, 07:31 PM
Thermo's Avatar
Spike, get the new stalk in there, then you can rip and shred as you see fit and if it doesn't go back together, then you are not out anything. This is how I do a lot of my projects and learn what I do.
Old 09-16-2014, 07:33 PM
Received 9,005 Likes on 4,113 Posts
Hope to hear.....
JimC64
31
05-30-2016 03:04 PM
inactualis
10-02-2015 11:13 AM
baskervillema
10-01-2015 06:43 PM
ChrisJay
09-27-2015 09:08 AM
UKnFor-dluv-expat
09-26-2015 08:40 PM
Quick Reply: Directional/Blinker chime or noise
