Jatco bearings
Jatco bearings
Looking for the two bearings on the differential (or final drive) inside the Jatco-- one is easy 32913 (the one mounted on the case) but the other that presses on the diff is impossible to cross (koyo stc6088)--it is a 60mm bore/85mm od/20mm thick
found 32012 but is 60/85/23
and 32912 but is 60/85/17
Anyone ever replace it and if so where did you find it?
David
David
