Jatco bearings
Old Jan 17, 2015 | 11:25 AM
Wahooesprit's Avatar
Default Jatco bearings
Looking for the two bearings on the differential (or final drive) inside the Jatco-- one is easy 32913 (the one mounted on the case) but the other that presses on the diff is impossible to cross (koyo stc6088)--it is a 60mm bore/85mm od/20mm thick
found 32012 but is 60/85/23
and 32912 but is 60/85/17
Anyone ever replace it and if so where did you find it?
David
Old Jan 24, 2015 | 07:11 AM
fourbyfourbyfar's Avatar
are these bearing tapered ones at either end of the diff i have my gearbox in bits at the moment and will have a look on monday and check with my bearing supplier
Old Feb 1, 2015 | 08:22 AM
Yes-the one that presses on the diff-I ended up buying a used box on ebay--swapping all the rebuilt clutch packs and other components over, and shelving the original until I find that one bearing and if so I will redo the box again and keep as a spare....
trickeyM
Oct 4, 2015 05:43 PM
Corycarlo
Oct 3, 2015 09:33 PM
inactualis
Oct 2, 2015 11:13 AM
Nic1635
Oct 2, 2015 01:30 AM
