rear defrost and radio issue
Old 11-20-2014, 11:09 PM
rob7157's Avatar
Default rear defrost and radio issue
Hello I am having a problem with my rear defrost and radio. Every time I put on my rear defrost it cuts out my radio was wondering if anyone else was having a similar problem?
Old 11-21-2014, 03:51 AM
GGG is offline
Received 16,800 Likes on 12,169 Posts
Welcome to the forum rob7157,
You should add whether there is any evidence of a PO fitting aftermarket audio or other electrical equipment.
Old 11-21-2014, 08:42 PM
wa3ra's Avatar
You likely have a ratty ground on the antenna circuit. The defroster puts out a pretty fair amount of RF, the crust between the body and the ground can form a diode-like circuit, which makes a pretty good detector for the front end of your radio.
It isn't that the radio doesn't work, rather the signal from the defroster swamps the radio receiver and you don't hear any stations.
Clean up the grounds at the antenna and defroster and you should be good to go!
Old 11-22-2014, 02:51 PM
astromorg's Avatar
In addition to wa3ra's advice, be aware that there is an antenna module through which the radio signals and power to the heater elements pass, so check the connections there as well. It's located behind the C pillar trim on the lefthand side. It's powered through Fuse F69, 7.5A in the glove box fuse panel.
JarodL
03-07-2024 01:39 AM
Harry Dredge
09-03-2015 03:04 AM
OkieTim
09-02-2015 12:48 PM
philwarner
09-02-2015 11:45 AM
innzane
09-02-2015 10:08 AM
Quick Reply: rear defrost and radio issue
