02 xtype wont start help plz
Old Jul 22, 2013 | 11:34 PM
lucasgirl08's Avatar
Default 02 xtype wont start help plz
Hey all hope someone can help me. How it started was my tail light went out ok kool replaced the bulb still no light drove to a friends to check fuses my husband pulled out one by one the fuses under the hood and we tried to leave and the car wouldnt start. Charged the battery nothing tryed to jump off the starter and the starter spinnes like it wants to start and it just won't. Someone help me plz I need my baby running.
Old Jul 23, 2013 | 12:23 AM
James Brandon Justice's Avatar
Talking Starter fluid
First thing you need to do is take off the MAF sensor a little bit of starter fluid down in the intake. If it starts you have a problem with the gas system, if it doesn't then you have a problem with the electrical system. From there we can help you narrow it down more...
Old Jul 23, 2013 | 12:24 AM
More then likely an electrical problem, seeing as you were playing around with the fuses. But, you never know with these cars.
Old Jul 23, 2013 | 01:31 AM
M9G's Avatar
M9G
Is the engine turning over but just not firing? - check the fuel cutoff switch hasnt popped out
In the UK the emergency fuel shut off is located in the driver foot well on the right hand side in a cut out in the plastic trim. In Left Hand Drive cars it can be found in the passenger bay foot well.
On top of this there is a rubber coated switch which you can press. If the shut off has activated you will hear and feel a small click when this is pressed.
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Jjscruggs1
Aug 2, 2017 04:40 PM
Kylejones
Sep 14, 2015 07:58 PM
Bones
Sep 8, 2015 08:34 PM
