Battery Not charging
The battery is likely on it's way out. Get the car checked to see if the alternator is charging the battery. If the alternator is charging you may have issues with the battery draining when the car is off. Make sure you don't run electronics in the car when the engine is off. Also make sure you lock your doors whenever you leave your car so all the electronics shut down completely. If none of that helps then you may just need a new battery.
