Battery Not charging
Old Oct 22, 2014 | 07:54 AM
joey4420's Avatar
Default Battery Not charging
anyone every got this yet? I have had it twice in the last week. Both times I was 2 hours from home so not a fun message to get at night not near home.
Old Oct 22, 2014 | 06:34 PM
hlgeorge's Avatar
That is not a common issue. I would have it checked out quickly.
Old Oct 23, 2014 | 11:08 AM
Blackcoog's Avatar
The battery is likely on it's way out. Get the car checked to see if the alternator is charging the battery. If the alternator is charging you may have issues with the battery draining when the car is off. Make sure you don't run electronics in the car when the engine is off. Also make sure you lock your doors whenever you leave your car so all the electronics shut down completely. If none of that helps then you may just need a new battery.
Old Oct 28, 2014 | 06:23 AM
joey4420's Avatar
Sorry for the delay in reply... been a busy week. The service department said they found a bad ground cable going to the battery and they replaced it. I haven't driven it much since, but will be making another trip to columbus soon... so I should know soon.
Old Nov 8, 2014 | 08:41 AM
Boston Joel's Avatar
I didnt get a warning but last Monday morning I got the infamous click-click-click. New battery solved it all. The OEM lasted 4+ years in mild climate.
Forcedair1
Sep 8, 2025 01:57 PM
Rivguy
Nov 13, 2022 02:55 AM
gold59
US Lower Atlantic
Sep 16, 2015 06:27 AM
Charlene n John
Sep 14, 2015 10:08 AM
jaguarbill
Sep 5, 2015 11:43 AM
