XF Brake Pad Replacement info needed
About to swap out the brakes on the 2009 XF. I find it completely unreasonable that the rear brakes are completely gone at 23,000 miles. My 2002 XJR is still on its original rear pads at almost 68,000 miles. does anyone know any "tricks" that make it easier to accomplish. I took off a rear wheel and it looks like you would unbolt 2 bolts to take the caliper off and then standard procedure from there.
does anyone know the torque specs for these bolts, lug nuts, etc?
thank you
thank you
Received 2,183 Likes
You should also know that the EPB needs to be released and re-set as part of the pad change. I think you have to disconnect the battery at some point but I may be mistaken. In any event you cannot just unbolt the calipers and replace the pads, the EPB will be adjusted to the worn out pads and the relined caliper won't go back onto the disc unless you release the EPB, which is electric. After you do that and fit the new pads the EPB has to be reset so as to be self adjusting.
Just push the park brake button down to release, and then after you set the pads after changing(nothing more than seating them to the rotors with a few stops forward and reverse) then pull up on the park brake switch and hold a few seconds while stopped with your foot on the brake. That simple
Escolar (09-06-2015)
How do you fully retract the pistons to allow installation of the new brake pads? The self adjusters on mechanical park brakes all have to be manually backed off to allow the new pads to be installed. Are you saying that somehow just releasing the EPB normally will also fully retract those pistons? That is not what I have read on other BB. If so, how does the EPB self adjust?
In the snow I have done handbrake turns using a conventional handbrake. Heck, in my Alfa Romeo 164 (which is fwd) I've done doughnuts in the snow using the handbrake to keep the spin going. Not brave enough to try this on bare road, yet.
The EPB answers a question I've never asked and I still don't see the advantage.
My last service yesterday (oil change only) at 39,000 km (24,000 miles) reveals the rear pads will need replacing before the next oil change is due (10,000 miles or 16,000 km).
Rotors are fine. Front brakes are fine.
We drive a lot on highways without needing to brake for long periods. This is pretty aggressive pad wear for our conditions.
BrentGardner
28
Today 03:08 AM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
