Supercharger oil change
Old Sep 9, 2012 | 06:30 AM
Poldek's Avatar
Default Supercharger oil change
Hello everyone.
I recently read some stories from XJR owners about changing oil in supercharger.
I know it's a easy DIY job and I'm only thinking, is this recommended to do if nothing is wrong with the supercharger?
I mean, I understand oil is getting tired over a period of time but it was supposedly last for life, according to Jag manufacturers.
Mine is 90k miles, works ok I think, sound ok, performs good I think. Shall I change it then? I'd like to make it work better but as they say if "it's not broken don't try to fix it".
Any comments will be apreaciated.
Thank you very much and regards to all.
Old Sep 9, 2012 | 08:22 AM
Doug's Avatar
Go ahead and change it. Can't hurt, might help, easy to do. And when you replace the black stuff that's in there with nice fresh oil you'll get some "feel good" reward out of the job. :-)
Old Sep 9, 2012 | 09:04 AM
Straight6DOHC's Avatar
I'd suggest you change it even if for peace of mind, but do your homework on where to get the correct oil. In UK at least, I don't know any suppliers of the oil off the top of my head and I've heard of at least one oil supplier recommending the wrong oil. Ask your local Jaguar or Land Rover dealer what oil they put in their superchargers. You don't need much but it's expensive and is often sold by the gallon. I got mine (maybe 250ml for around £30???) from a SC rebuilding shop which I don't think is operational now.
Old Sep 9, 2012 | 09:50 AM
Doug's Avatar
Since both GM and Ford having been using Eaton superchargers for years there are some choices. I use GM #12345982 which is a mere fraction the cost of the Jaguar-labeled stuff. Don't know the Ford part number.....and not sure about UK availability of either.
Old Sep 9, 2012 | 04:52 PM
Poldek's Avatar
Thank you very much for the advise. I found some stuff on eBay, one kit contains BP turbine oil, the other is the Eaton oil that everyone recommends here on forums.
And since this is fairly easy job to do I think I will have a go and change it. As you guys saying, new oil wont hurt. Once I do it I will post it herr how it all went and how it feels.
Thanks again.
Old Oct 13, 2012 | 06:25 AM
kj217's Avatar
how to change oil of supercharger?
Old Oct 13, 2012 | 06:48 AM
Doug's Avatar
On the older models such as mine you simply remove the filler plug and insert a suction tube. I use a "Mity Vac" suction gun.
Your car is much newer and might require a different procedure....so you might want to re-post in the correct section for your 2005 Jaguar.
Old Oct 19, 2012 | 11:22 PM
shaune's Avatar
Default Part # changed
The new part # for the Supercharger oil is GM #10953513. I bought 2 bottles yesterday. If you are buying from eBay then you can still search using the part # Doug posted.
http://www.acdelcochemicalcatalogue....h_frn=&search=
bamforp
Aug 14, 2024 05:36 PM
Jpav27
US Northeast
Dec 17, 2021 05:40 AM
ZJag
26
Sep 5, 2016 03:33 PM
Jag-o-nomic
Sep 4, 2015 03:07 AM
pnwrs2000
Sep 3, 2015 11:55 AM
