Airbag light illuminates on braking
Old 09-02-2013, 02:45 PM
PJVeal's Avatar
Default Airbag light illuminates on braking
I have an 98 x300, just recently the airbag light started coming on when the car brakes or accelerates sharply, it stays on until the engine is switched off and then goes off again and repeats the process again. Any ideas?
Many thanks in advance.
Phil V
Old 09-03-2013, 03:20 AM
Sean B's Avatar
Received 1,341 Likes on 1,057 Posts
check the wiring under the drivers seat, you'll have to move it all the way forward, maybe unbolt it, it's 4 torx bolts at each corner of the seat, tip it forward and carefully inspect each wire and connection. My guess is there isn't a fault with the bags, but the wiring chaffed somewhere.... I'd suspect the drivers seat if no passenger is present.
PJVeal (09-04-2013)
Jpav27
07-31-2022 06:43 AM
H20boy
07-23-2021 09:39 PM
motorhead69
09-09-2015 10:04 AM
Mosers63
09-06-2015 02:53 PM
Doovoe
XJ40 ( XJ81 )
09-06-2015 10:54 AM
Quick Reply: Airbag light illuminates on braking
