PRND Gearbox Lighting issues
Old 09-16-2016, 05:13 PM
XJ8Lou's Avatar
Default PRND Gearbox Lighting issues
Hi all,
Was wondering if you guys knew what bulbs I need to replace my PRND gearbox lighting? (pic isn't the best, but from P to R the green line doesn't light up. same with the 2 to 3) I tried to take it off myself today to have a look but did not want to risk breaking parts.
Thanks!!
Attached Thumbnails PRND Gearbox Lighting issues-14360477_1276751932343992_397933735_o.jpg
Old 09-16-2016, 08:11 PM
Addicted2boost's Avatar
https://www.jaguarforums.com/forum/xj-xj8-xjr-x308-27/j-gate-shifter-lighting-135578/
I just replaced the 2 soldered in backlighting bulbs. Replace them both at the same time. If you'are also not getting some of the red letters, those are red LED's and I don't have any information on those. If you are doing the soldering, take your time with the whole process.
Old 09-17-2016, 03:20 AM
Stu 1986's Avatar
The link addicted posted is a good link created by a friend of mine. The process is easy if you're experienced with electronics but take your time all the same.
XJ8Lou (09-23-2016)
Old 09-17-2016, 10:14 AM
Samilcar's Avatar
https://www.jaguarforums.com/forum/x...cklight-75330/
It looks like your upper backlight lamp is out. Both of mine were out, I used Chicago Miniature 8097 bulbs for replacements.
XJ8Lou (09-23-2016)
Gondolaboy
09-17-2016 08:51 AM
shemp
09-14-2016 01:25 PM
LoveIt
09-13-2016 06:18 PM
davetibbs
09-12-2016 03:20 PM
Tatty
09-12-2016 02:18 PM
Quick Reply: PRND Gearbox Lighting issues
