p1111 and p1647 will not start
I've moved your post to a new thread.
Please visit New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and introduce yourself, then we can say 'Hello' and get down to business!
P1111 is OK, just means diagnostic cycle is complete.
1647 is trickier.....
P1111 : OnBoard systems tests completed
P1647 : ECM HO2S control malfunction - B Bank upstream
Possible Causes
1. HO2S heater failure
2. HO2S sensing circuit short circuit to ground or high voltage
3. HO2S sensing circuit open circuit
4. ECM failure
The P1111 is nothing to worry about. You will always get either P1000 (tests not completed) or P1111 (tests completed).
For the HO2S, start by checking the connections before assuming sensor failure. You will be very unlucky if it's an ECM failure.
Hibbitt (12-17-2012)
