p1111 and p1647 will not start
Old Sep 29, 2012 | 09:55 AM
HazelEyedFool's Avatar
Default p1111 and p1647 will not start
2002 xj8 will not start problems ... code 1647 and code 1111 ... dont know where to start or what to try ... any one out there?
Old Sep 29, 2012 | 10:11 AM
steveinfrance's Avatar
I've moved your post to a new thread.
Please visit New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and introduce yourself, then we can say 'Hello' and get down to business!
P1111 is OK, just means diagnostic cycle is complete.
1647 is trickier.....
Old Sep 30, 2012 | 08:02 AM
ok i posted there ... and how do i find the new thread ... any help with be welcome
Old Sep 30, 2012 | 09:25 AM
You're already there- there's an automatic redirect.
You can follow your posts by clicking on 'My Posts' in the black menu bar or set your User CP preferences to email you when someone replies.
Old Sep 30, 2012 | 01:42 PM
Codes
P1111 : OnBoard systems tests completed
P1647 : ECM HO2S control malfunction - B Bank upstream
Possible Causes
1. HO2S heater failure
2. HO2S sensing circuit short circuit to ground or high voltage
3. HO2S sensing circuit open circuit
4. ECM failure
The P1111 is nothing to worry about. You will always get either P1000 (tests not completed) or P1111 (tests completed).
For the HO2S, start by checking the connections before assuming sensor failure. You will be very unlucky if it's an ECM failure.
Old Oct 1, 2012 | 06:27 AM
P1647 shouldn't stop the engine starting, it will just stick in 'open loop'.
Can you give us a bit more about the non-start condition?
Dagny
Jun 11, 2024 01:06 PM
99xk8guy
May 28, 2024 09:36 PM
JarodL
Mar 7, 2024 01:39 AM
Bones
Sep 8, 2015 08:34 PM
Doovoe
XJ40 ( XJ81 )
Sep 6, 2015 10:54 AM
