Go Back   Jaguar Forums - Jaguar Enthusiasts Forum > Jaguar Models > XJ ( X308 ) XJ8 / XJR
Sign in using an external account
Register Forgot Password?
Search
XJ ( X308 ) XJ8 / XJR 1997 - 2003
LinkBack Thread Tools Search this Thread
Old 06-13-2010, 10:40 AM
Default XJ8 Speaker size conflicts 5.25 or 6.5? Results!
Ok So yesterday i was bored as hell at my house so I took it upon myself to get the speaker out of my 1999 XJ8. There has been conflicts on websites and forums about the size of the all four speakers. But I finally have the real answer. First in order to get the speakers remove you need to remove the door panels. There is a screw behind the door handle and a long screw under the arm rest. The original speakers are 6.5 inches. even though the speaker's grill is about 5.25. But remember the cover is on top of the door panel cover therefore it looks like there are small speakers behind this Harmon Kardon branded cover. Anyways i was able to fit confortably a Kenwood eXcelon KFC-X173 6.5" Round 2-way 2-Speaker System. The Magnet is a lot bigger compared to the originals but still was able to fit perfect. Below is a website that you can get these speakers at a competive price. You have their asking price then you click on the " lowest price guaranteed" button and hyou get these 1 pair ofspeaker at such affordable price. So far I bought the speakers from 6th ave electronics for 83.00 sale price but it was worth the extra money just to see if the speakers fitted correctly. Last night i bought the same speakers from the website below at 62 bucks and FREE S/H!
Now I need to know what size is the one rear window speaker. Yes only one speaker. If anyone knows the answer let me know. Thanks !
As soon as I am able to post pictures i will post the pics of the original speakers for everyone to see.
BTW these speakers are awsome with the base with the original radio.
http://www.al-eds.com/product.php?productid=21373
Old 06-13-2010, 11:01 AM
H20boy's Avatar
my guess is that 'single' speaker (sub) in the parcel shelf (I assume that is what you are referring to?) will be a very odd size.
Good project though, glad you had some success!
__________________
Matt | 2003 XK8 CvTbl | 2005 SuperV8
My Jag Galleries
Go Texas Tech!
Old 06-13-2010, 11:06 AM
Thanks H20boy. I guess i am going to find out myself in a few. Let's see what happens so far getting kind of bored again. lol
Old 06-13-2010, 05:42 PM
H20boy's Avatar
Quote:
..normally I would say that could be dangerous.
__________________
My Jag Galleries
Go Texas Tech!
Old 06-13-2010, 09:14 PM
QuadManiac's Avatar
In my 2000 XJ it's a 6x9 dual voice coil subwoofer. Not too easy to find a drop in replacement.
Mine had a fried surround when I bought the car. I rebuilt it with a surround kit from SpeakerWorks.com - around $10, worked perfectly... I've used their surround repair kits to rebuild everthing from car speakers to my old Bose 901 home systems.
http://www.speakerworks.com/6_by_9_i...t_p/swk69a.htm
__________________
2000 XJ8 Anthracite/Charcoal
Old 06-13-2010, 10:16 PM
How do you removed the speakers? from the top or the bottom?
Old 06-13-2010, 10:17 PM
BTW I did not get the chance to open it up and find out myself yet/
Old 06-14-2010, 08:09 PM
JaguarXJR02's Avatar
removing the subwoofer in the parcel shelf is kind of a pain, I did it about a month ago to replace my busted subwoofer.
You have to remove the entire rear seat bottom and the entire rear seat back. you also have to unbolt the seat belts and if you have rear heated seats you have to unclip the wiring harness.
then you have to remove the parcel shelf deck, which they claim you can "bend" it over the seat belt coils but I didn't think that was reasonable so I just unbolted the seatbelt coils. I also removed the paneling around the little rear side windows so I could get the rear deck out with less issue. Also it is a good idea to remove the plastic cover from the third brake light in my opinion.
Old 06-15-2010, 12:00 AM
OMG it sounds like a determined mission. Can you confirm the size of the speaker? Thanks Jaguarxjr02
Old 06-15-2010, 04:03 AM
QuadManiac's Avatar
Yes, it is a bit of a pain, but I've done it twice now (once to repair the sub and the second to run wires for an AUX input to the CD changer and a Sirius antenna) and the second time was much faster. The parcel shelf removed over the seat belt recoil mechanisms with no issue for me, nor did I remove the side paneling. Only had to remove the child seat safety strap hangers from the shelf, the plastic cover over the third brake light.
The rear seat back is easy - remove the bolts (4), pull up the plastic feeds for the seatbelts from the top rear of the seat back, then tip the seat back forward - leave the seatbelts in place coming through the seat back top slots... the belts just unreel.
It is definitely a 6x9 with dual voice coils, the surround repair kit I referenced above fit perfectly.
__________________
Old 06-15-2010, 12:42 PM
Thanks for the info. I guess i can make time to this this upcoming weekend. I will keep you posted how it went. I might as well put the AUX cables while i am at it even though i am using the take deck (cables) for my ipod.
Old 06-15-2010, 06:38 PM
QuadManiac's Avatar
Tape deck cables? You mean you're running the iPod thru a cassette adaptor? Direct connection (through the AUX mod) will make a huge difference in fidelity.
__________________
Old 06-15-2010, 07:33 PM
everything everyone else has said is true, speaker size is 6x9 for sure
Old 06-16-2010, 12:57 AM
lol. I know how sad that is about my cassette cable Maniac
I will try it the other way though.
Old 06-16-2010, 12:58 AM
6x9 it is then!
Old 06-24-2010, 09:05 AM
PeterCrespin
Guest
Posts: n/a
Quote:
Originally Posted by QuadManiac View Post
The rear seat back is easy - remove the bolts (4)...
Hello - first post here. What is the procedure for the individual reclining rear seats please? (99 Daimler SuperV8). My rear parcel shelf has some discolouring on the trim material and I'd like to re-trim the fabric section.
Pete
Old 06-27-2010, 11:00 AM
Don't know if this helps but i tried it and it looked intiminating.
Let me know if able to do it. IF so Pictures please so i can see it visually.
Old 06-27-2010, 11:03 AM
Well this may help you too. I still have not done mines yet but am dying to get the 6x9 change
Old 06-27-2010, 03:23 PM
QuadManiac's Avatar
Quote:
Pete
1) Your first post should be in the 'New Member Area' to introduce yourself.
2) You have hijacked an existing thread to post a new, different problem... you won't get much attention. You should post this as a new thread - hopefully you'll get lots of responses.
__________________
Old 07-21-2010, 07:34 AM
Default tweetr size
Hi,
I'm trying to find out the specifications of the tweeters of the XJR year 2000 premium audio system.
there are four of them, two in the A-posts and two in the back doors, behind the handle.
thanks.
__________________
Jaguar XKR Silverstone (+ Jaguar XJR 02/2000 R.I.P.)
Tags
1999, 2000, 2003, 6x9, 99, back, fit, jaguar, remove, replace, seat, size, speaker, speakers, xj8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Copyright © 2010 Internet Brands, Inc. All rights reserved.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013 vBulletin Solutions, Inc. All rights reserved.
SEO by vBSEO ©2010, Crawlability, Inc.
JAGUAR and its logo are the registered trademarks of Jaguar Cars Limited. Jaguar Cars Limited is not affiliated with JaguarForums.com.
