XJR Restricted Performance
Old 04-01-2013, 06:53 PM
rwilli's Avatar
My 2000 xjr is giving me the same problems. The technician said my K&N air filter was causing the problem. The dealer replaced it with a "factory" air filter for $65.00! It sounds like BS to me but I'm desperate to get the problem solved! I'm going to check the vacuum lines as suggested.
Old 04-01-2013, 11:08 PM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
You would not be the first to report problems with the K&N filter!
Old 04-04-2013, 02:21 PM
Last Jaguar's Avatar
hello there, once i watched this video and idea struck me. maybe this is some how connected with ur issue? i know this is a different car, but still...
check out this link
Old 04-05-2013, 03:17 PM
Blue_XJ8's Avatar
For what it's worth - I also had the restricted performance issue on my '01 XJ8. Strangely enough, this happened just after I installed K&N filter. BUT, turned out it was not related - or at least the code I was able to get was knock sensor malfunction on Bank B. $25 and 20min later, replaced knock sensor and problem never re-appeared (and still gladly have the K&N fitted!).
D.K
12-10-2023 02:05 AM
xjrjag
09-27-2015 01:53 AM
kevo
09-08-2015 09:45 AM
XFR_Gold
09-02-2015 12:24 PM
Quick Reply: XJR Restricted Performance
