XJR Restricted Performance
Old Apr 1, 2013 | 06:53 PM
rwilli's Avatar
My 2000 xjr is giving me the same problems. The technician said my K&N air filter was causing the problem. The dealer replaced it with a "factory" air filter for $65.00! It sounds like BS to me but I'm desperate to get the problem solved! I'm going to check the vacuum lines as suggested.
Old Apr 1, 2013 | 11:08 PM
sparkenzap's Avatar
You would not be the first to report problems with the K&N filter!
Old Apr 4, 2013 | 02:21 PM
Last Jaguar's Avatar
hello there, once i watched this video and idea struck me. maybe this is some how connected with ur issue? i know this is a different car, but still...
check out this link
Old Apr 5, 2013 | 03:17 PM
Blue_XJ8's Avatar
For what it's worth - I also had the restricted performance issue on my '01 XJ8. Strangely enough, this happened just after I installed K&N filter. BUT, turned out it was not related - or at least the code I was able to get was knock sensor malfunction on Bank B. $25 and 20min later, replaced knock sensor and problem never re-appeared (and still gladly have the K&N fitted!).
xjrjag
Oct 24, 2024 03:09 PM
D.K
Dec 10, 2023 02:05 AM
kevo
Sep 8, 2015 09:45 AM
XFR_Gold
Sep 2, 2015 12:24 PM
